Alfred.NESWADBA
en respuesta a: johnyDFFXO
>> I din't wanted to twist the view every now and
>> then for every single element
No need to do that. Split your modelspace to two viewports (command _VIEWPORTS and then select e.g. "Two: Vertical").
Then in the left view you have the top view, activate the right view and change it to a 3d-view.
Now you can select in the top view with crossing your double (or multiple) overlaying objects, these will get then grips displayed ... on the right view you see the gripped entities and so  also their Z-value.
Is that something useful for your work?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
