826 Vistas, 2 Respuestas
Current layer is stuck when I use a hatch
When I use a hatch on the layer, the hatch that shows is from a different layer. It does not matter witch layer I choose for a hatch, he's always going back to one layer, witch the layer is stucked. Do you now a solution?
Alfred.NESWADBA
en respuesta a: Anonymous
Looks like you have set HPLAYER to this one layer, not to user "current layer" (>>>details<<<).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
beyoungjr
I believe @Alfred.NESWADBA may have identified your problem.  The system variable that he suggests should help.
In case you would like to see where this variable is controlled in the GUI...
Ribbon...
Legacy Hatch Dialog...
Hope that helps too,
Blaine
Blaine Young
Senior Engineering Technician, US Army
