Alfred.NESWADBA
en respuesta a: shollins23
>> emails form clients about the PDF's I send not printing properly.
>> [...] I can print it fine so it's difficult to problem solve
A bit more info is needed...
  • Which viewer do you use to print?
    Which viewer does your client use to print?
  • Which device and driver was used by the client to print your PDF to?
  • Which software was used to create the PDF?
  • Which driver was used in the above software to create the PDF?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
