213 Vistas, 2 Respuestas
Imported Word doc will not print to PDF unless vp is refreshed several times
I have a word .doc schedule that is imported into AutoCad. When I print to PDF I have to refresh the view port every time to ensure the word doc will print. The view port is on a no plot layer and the word doc is on separate  plot layer. How do I fix this problem so I don't have to refresh viewport every time I print sheet? Is there a setting I can set to fix this problem?
vinodkl
en respuesta a: Anonymous
How did you import the word doc. OLE?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
imadHabash
in the same drawing , if you make another new viewport in a new layout tab , any changes ?
if you insert the word .doc schedule to a new CAD drawing , any changes ?
Imad Habash
