vinodkl
en respuesta a: Anonymous
The pdf converted from dwg, when re-imported back to dwg will have distorted elements as the AutoCAD can't recognize the few of the elements. while most of the object will be imported as it was in dwg. What can be done is to redraw the elements which are distorted. You could have the option " infer linetypes and collinear dashes" check while using PDFIMPORT which would replace each set of collinear dashed segements with polyline, like if there are any dashed lines in the drawing it will be replaced with dashed linetype rather than small unjoined line segments.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
