844 Vistas, 4 Respuestas
Pdf import issue
When I export my AutoCAD drawing to a pdf file (dwg to pdf), then re-import the pdf file again into AutoCAD, the lines of the drawing are distorted (lines from the imported pdf; exported from AutoCAD, are different than the lines from the original AutoCAD file).
Is there a way to fix this or a workaround?
