TheCADnoob
en respuesta a: Anonymous
Try going from Autocad to dxf and from dxf to inkscape.
Im not sure this will solve your problem but I think the dxf should be a cleaner route
edit: i just tried this and seems to solve your problem (if i understood it correctly) The text field came in as an editable text field. There was some changes in the text size but it looked as though the text insertion point was where it was in the dxf (dwg) file.
CADnoob
