2058 Vistas, 7 Respuestas
AutoCAD to SVG bad text formatting
I am currently trying to convert a .dwg to .svg, and then replace text fields on the svg with new text. However, the svg remembers the position of each letter in the svg file, so when inputting new text, the new text is spaced according to how the (different) text in the svg was spaced. I want to make it so that the svg only remembers the position of the first letter, without having to go through the svg's xml code
