2433 Vistas, 11 Respuestas
Publish Page Set Up Overrides as individual PDFs
I'm trying to publish sheet sets via the sheet set manager with a particular plot style while also publishing the set as individual PDFs that retain their respective sheet names.
Publish using page set up override -> custom page set up -> always publishes as a single PDF
PDF options in the page set-up does not have the multi-sheet PDF box to uncheck like is in "sheet set PDF Publish Options" where i can uncheck multi-sheet file.
What options do i have? can i change the default plot style for the generic "publish to PDF." I could at least then publish them as individual PDFs.
HELP. and thank you!
Etiquetas (2)
imadHabash
en respuesta a: Anonymous
if you have the right settings , please restart your AutoCAD and start publish, any changes ?
Imad Habash
en respuesta a: imadHabash
What exactly are the correct settings??
leothebuilder
Publish-> Publish Options-> de-select the Multi Sheet file check box
en respuesta a: leothebuilder
It has been unchecked. the issue is when i publish using a sheet set override it still publishes as a multi-page PDF. is there a solution for this? i cannot find any options within the override page set up.
pendean
Post a screenshot of your PUBLISH command (all ready to go) and a screenshot of the PUBLISH SETTINGS pop-up where you set he PDF type, let's see what you have going on.
And what is your exact version an variant of AutoCAD as listed in ABOUT command?
en respuesta a: pendean
Thanks for the reply. I've found somewhat of a workaround by just setting my default plot style to my custom ctb file in the options menu. Fortunately, all of my sheets page setups are the same so now that I have a default plot style set it will publish my set as individual PDFs with the correct plot styles.
Thank you!
sepideh.m
I have the same problem.
Could you please explain how I can set the default plot style to my custom ctb?
cadffm
en respuesta a: sepideh.m
WHAT is your problem?
Because you can not have a plotstyle you want to add to a ctb :cara_guiñando_un_ojo:
You can add a plotstyletable(a ctb file for example) to the plotstyle folder.
Which folder?
Command Stylesmanager
And if this is not what you need, tell us what your problem is.
Sebastian
sepideh.m
en respuesta a: cadffm
Thank you for your response CADffm.
The problem is that I want to publish some selected sheets of a sheet set to individual pdfs using my settings (including ctb, transparency, etc). :cara_con_una_leve_sonrisa:
I have unchecked the "Multi-sheet file" in the Sheet Set PDF Publish Options.
I select the sheets, right-click > publish, then I will have two options:
1- "Publish to PDF" will create individual pdfs, but it's not using my setting.
2- "Publish using Page Setup Override" and selecting my page selected, will create one multi-page pdf (which I'm not looking for), with the setting I want though.
I checked the Stylemanager, it will open a folder where some of titleblocks and ctbs are in. The ctb I want to use is also there.
jsloanTX3CG
Set “PUBLISHCOLLATE” to 0
raquinoNKK5Z
en respuesta a: jsloanTX3CG
thanks for this
i had the same issue as OP and this fixed it
