428 Vistas, 4 Respuestas
Why can I not delete one layer, when I see nothing in it?
In the drawing attached, I cannot delete the layer called "forces1-finished"
but I can not see anything in it.. can anyone see why i can not delete it?
Alfred.NESWADBA
en respuesta a: Anonymous
starting command _PURGE was able to purge the layer "forces1-finished".
I was also able to use layer-manager and delete that layer.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
Nothing weird noticed . by direct Delete from Layer manage and Purge ... it's gone .
Imad Habash
en respuesta a: imadHabash
very interesting. now i am able to delete it too. i really could not delete it when i opened and closed the file few times before and i changed absolutely nothing in the drawing, i definitely did not delete anything that belonged that layer as i never found anything there, even when i was not able to delete it. anyway thanks to all... .
illusionistNUGXG
I also had no problem deleting that layer with PURGE in your file.
In other cases - More reasons for not being able to delete a layer can be:
An object using this layer is overlooked somewhere in one of the layouts.
That Layer is used in a block - even if the block is nowhere inserted in the drawing!
