08-15-2019
10:39 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-15-2019
10:39 PM
The issue here is getting the font you want into the table. True Type fonts can give you problems; using the Alternate Font setting tells AutoCAD which font to use as an alternative. You can go through the Options menu ( Options > Files tab > Text Editor, Dictionary ) , or just type FontAlt on the Command line and tell AutoCAD which font to use.
>> Is there a work around to make the cell text size change globally?
To change the text size, select a cell, then hold Shift and drag to select all other cells. With all cells selected, go to Properties and change the text height.
also you can follow here another way that may help . >> Click <<
Imad Habash
