pendean
en respuesta a: Anonymous
That's all fine and dandy for the other ladies, but since no one here is "autodesk", you need to try a bit harder for us to try and help you out.
Is what you are describing be better explained as "...windows covering other windows/pop-ups..."
Can you post screenshots from your PC and from one of the other PCs so we can see the difference?
If you log-in as an all new user on your PC (your IT will need to help) does the problem go away?
