BeKirra
en respuesta a: Anonymous
@Anonymous
"Which Command in AutoCAD combines a 2d and 3d object .
Does @imadHabash reply help?
I don't know what kind of "combination" you are looking for but command group might give you another idea.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
