2310 Vistas, 5 Respuestas
Plotted PDF shows image in wrong color compared to DWG file
Summary: I faced distorted colour output in plotted PDF in AutoCad 2017 which I just recently installed in my new company Lenovo T480 laptop.
Background:
Previously I was using AutoCad 2013, every company image inserted into DWG file plotted on PDF was as per the colour shown on AutoCad Model Space. However the problem arises after I changed a new laptop where company policy required me to install AutoCad 2017.  The plotting in AutoCad 2017 looks the same, I applied the same Page Setup(I even copied and apply the Page Setup I used in AutoCad 2013). But the colour still distorted after plotted.
Steps taken by me so far:
1. I have copy and pasted the ctb/stb file in Plot Style but the problem is still there.
2. changed every settings available in Option Menu->Plot & Publish
3. Disabled and Enabled Hardware Acceleration
4. Changed every settings in Hardware Acceleration
5. Changed Table Style Plot Setting under Plot & Publish Menu.
Cover.DWG is the actual file
Cover.PDF is the plotted file
Attachment Description: By comparing both files, it can be seen the colour on the image inserted in DWG is changed/distorted/inverted as compared to PDF file.
So, can I get assistance and help me to shed some lights?
Thank you very much.
