Kent1Cooper
en respuesta a: Anonymous
It sounds to me as though either there is actually a Z-coordinate difference [which Dimensions will ignore but which the DIST command {= the MEASUREGEOM Distance option} will "see"], or the Dimension has a linear scale factor applied, either in its Style definition or as an override.  The former is easy to test for -- look at the entirety of what DIST returns, because it includes a delta-Z value and an angle from the XY plane, both of which will be 0 if things are truly 2D.
Kent Cooper, AIA
