Alfred.NESWADBA
en respuesta a: Anonymous
>> Dimensions produced by the DIM command seem correct
>> compared to the pdf file
A PDF file can show some text, but does not show any real dimension as it is scaled to a paperformat and never a 1:1 size.
>> when I try using the Measuregeom tool, results are inaccurate
>> by slightly more than 100% larger measurements
If _DIST shows a different value to the expected value than most probably the geometry you have measured is incorrect drawn.
>> I have no idea how to correct this
You might scale the geometry using option _REFERENCE within the command _SCALE.
But first I would look to the source of the issue. Where are the data from, and at which step started the incorrect size.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
