Alfred.NESWADBA
en respuesta a: Anonymous
sorry, password protection is not possible with AutoCAD.
>> I need to be sure when i share the file that the person
>> can't give it to someone els and they can make changes
>> to it or copy it over to a new DWG file
The only really secure option that someone else can not use your data is to not give your data out. All other methods, even giving a paper to someone else, gives them the possibility to scan, vectorize and work with that.
Also watermarking objects would not work well as I would then save to DXF, remove the extended information and have the geometry to continue to work.
The best you can do is to use contracts which define what is allowed or not with your data.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
