08-08-2019
11:22 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-08-2019
11:22 PM
I tested for you with 2020.0 (but with Block-Bugfix): Not Problems with Layout import.
Tested: Contextmenu -> Add Layout and Drag&Drop to the target drawing-editor window.
ABOUT Productversion Q.47.0.0
VERNUM Productversion Q.48.0.0
_
Try it again with brand new files and Layouts, save both files in dwg2018 Format.
Still a problem? If not, it seams there is a problem with 2020 and your usual source file.
(If you like, share the file and we all together search for the problem).
Try a quick solution: Open the file by RECOVER, -PURGE REG, Purge all, saveas dwg2018. Try it again.
Sebastian
