en respuesta a: Alfred.NESWADBA
Brilliant. This goes a long way to helping me achieve what I need. I hadn't realised the units were default as I thought the settings had carried over from LT, so with those changed from inches to mm hopefully that will allow me to put the exposure and light settings on a more normal level.
With regards to what I said about pointed edges, I realised it was an issue with the default settings again, just needed to increase the arc and circle smoothness.
With my scene it's a little tricky, as its going to go on a document and requires transparent background - so would need there to not be ground shadows or a wall/floor. Ideally I just need fairly even light, so perhaps a couple of lights from the front and side angles will suffice. I'll look into what each type of light brings to a scene and from there play around with them to see which gets the best results.
Great help though, thanks!
