- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> the output seems to have a few lighting issues
Yep, there is no light in your scene.
AutoCAD tries to create a realistic result, in case you have a room without light (and window) you also have a lightning issue. AutoCAD can avoid the situation that there is no light as it sends some default lightning, but that (in most cases I know) don't really help with the scene.
Dimensions ... Is that correct, that your screws are 10 Inch long, that your current switch device is 35 Inch wide? If not then you should take care about the dimensions and the light fitting to these dimensions. E.g. the blue block is 1000 Inch high (3.93m), a small lightbulb on top of that block will not make the bottom of that block really bright.
Either your units are wrong or you need lights that are more headlights than just the default light or lightbulbs.
>> to improve the slight blur that appears on the main render
Can you please describe what you see as "blur" in the main image (when you look to it at 100% zoom level).
I can't identify anything as blur (just the shadow, but that should be ok as it's just an unspecific default lightning).
>> the sockets (and the cut outs on the panel behind) are showing
>> with pointed edges and not smoothly rounded
Not sure where you see pointed edges or none smoothly rendered ...
That's what I get from your drawing (without changing anything, just zoomed in):
>> I'm now wondering whether I need to adjust the sunlight
>> settings or whether I'm better off adding lights
If you want to have an outdoor scene, you'll need the sun.
If you want to have an indoor scene, you need lights ... and don't forget, you also need the walls around your scene, otherwise your light rays are sent to the infinity instead (as in the reality of an indoor scene) reflected from the environment like wall, window, floor, ceiling, ...
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
