08-07-2019
02:47 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-07-2019
02:47 PM
@PBESSmgr schrieb:
>Why?
Read below
>Is this because of the xrefs or clip? Can it be changed?
No, nothing to do with xrefs or clips, just missing basic AutoCAD knowledge for Layouts&Viewports
>I want to reposition the view in layout 3.
Then: DoubleClick into the Viewport and use command PAN (or Zoom and so on, commands to change the current view)
>I dbl clk in viewport, click Move,
STOP! When you doubleclick inside a viewport, you are in MODELspace, if you change objects, for example the the position by MOVE command, cou change the objekts in your modelspace..
All Viewports are looking to the content of your modelspace and if you move an object, you will see it
in all viewports (when current view display this area)
>select all crossing within the viewport, enter, click on base point, drag the view up afew inches,
You don't "drag a view" axcept you would use the PAN command.
You talk about to edit your model!
Sebastian
