08-07-2019
02:43 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-07-2019
02:43 PM
If I understand right, you are in a paperspace viewport, and you then select all the entities in modelspace, move them, and then you see that they have also moved in the other viewports on your other layouts.
That's how it's supposed to work. When you move the entities in modelspace, that will be reflected in every viewport.
If you want just that one viewport to show a different portion of the objects in modelspace, stay in paperspace on that layout, and use the grips to move the extents of that one viewport around. Or use the <stretch> command to move the viewport extents.
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
