- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
There has been lots on information on how to turn the middle scroll wheel as pan. I use the middle button for a snap menu instead. I despise the middle button as a pan option. Anyhow, Mbuttonpan is set to 0, I have exhausted all efforts to try to get my snap menus back as my middle button. How do I get my middle button snap menu back. I have been using the snap button menu for the last 15 years, so learning to use the pan function does not work for me.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Can't go back a decade ago, hold the shift key or Ctrl key down and middle button that's all you get.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I had a computer upgrade in the last couple of weeks, The CUI file has been changed. I am still running the same version, just on a different machine. It worked 3 weeks ago it should still work. While I appreciate the sarcasm, the problem remains in the CUI changes. Shift-click does nothing either.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes I have, Right now if I push the middle button, the Aperture & Cross hair go off when I hold the button down, they come back when I depress it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
When I change MButtonPan to 0, I get the shortcut menu. Tested in MEP 2020 and LT 2020. Maybe it's a mouse setting.
BTW, pushing the button and depressing it are the same thing.
@Anonymous wrote:Yes I have, Right now if I push the middle button, the Aperture & Cross hair go off when I hold the button down, they come back when I depress it.
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The mbuttonpan is set to 0, that's whats so confusing about it. It's not a mouse setting either, tried that one.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The behavior you want is default when MButtonPan is turned off. Since you reset to default settings, I am leaning towards your new hardware.
Are you running any vertical products?
Do you get any menus when you right click?
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I will be re installing the version and will remake all my custom settings hoping it will reset back to the default settings in Cad.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I wouldn't go all nuclear, yet, but that's up to you.
I did ask a couple questions that might reveal what the problem is. Would you care to answer them?
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have reinstalled 2020 and it works fine now, when it was initially installed the settings were migrated over from 2017. The middle button now has the snap menu.
