Alfred.NESWADBA
en respuesta a: haaris441
>> i need the dimensions to get updated when the rectangle is changed.
Not sure if I understand the question correct ... if you have placed dimension objects and you have activated DIMASSOC the dimensions will update themselves if you change the contour of the polyline.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
