Alfred.NESWADBA
en respuesta a: dawson.lim
these are the differences:
  • you are using AutoCAD 2010, "she" is using AutoCAD 2018, 2010 has a much older version of "DWG to PDF" driver.
  • you are plotting to A4, "she" is plotting to A0, which means her output is much bigger, so displaying on the display with the same size means a very different display scale.
- alfred -
PS: "she" should install updates for AutoCAD 2018, there is no update installed, but update 2018.1.2 is available (and the must current one today).
Alfred NESWADBA
(not an Autodesk consultant)
