Alfred.NESWADBA
en respuesta a: dawson.lim
>> how could I change my autocad setting so that it
>> will not convert text to vectors?
Start command _PLOT, then select "DWG to PDF.pc3" as device ==> PDF Options and look to this setting:
This seems to be your setting, now:
  • uncheck "Convert all text to geometry"
  • check "Capture fonts used in the drawing"
  • now create your PDF.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
