dawson.lim
1579 Vistas, 14 Respuestas
Text Printing Not Sharp
I am using AutoCAD 2010, I always facing a problem when PDF the drawings. The text appear to be very "ugly" and not sharp enough. However, when my friend (using her AutoCAD), she can print the text very sharp. Attachment: 1. My Printing ( the one I plotted using built-in DWG to PDF and monochrome plot style) 2. Her Printing (same printing system with mine) 3. The native DWG file.
Etiquetas (1)
Alfred.NESWADBA
en respuesta a: dawson.lim
"Her printing" was created without converting the text to geometry, the text is searchable.
"My printing" has converted the text to vectors, that seems to be the difference.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
rkmcswain
Open both PDFs in an editor (such as Bluebeam). Go to the Document Properties.
Your PDF does not have any truetype fonts embedded, the other PDF does.
dawson.lim
en respuesta a: Alfred.NESWADBA
Hi Alfred, how could I change my autocad setting so that it will not convert text to vectors?
dawson.lim
en respuesta a: rkmcswain
Hi rkmcswain, any reason why autocad in my computer not printing the text out as truetype font?
Alfred.NESWADBA
Start command _PLOT, then select "DWG to PDF.pc3" as device ==> PDF Options and look to this setting:
This seems to be your setting, now:
  • uncheck "Convert all text to geometry"
  • check "Capture fonts used in the drawing"
  • now create your PDF.
- alfred -
Alfred NESWADBA
rkmcswain
Yes, the driver you are using is not configured to embed the fonts. How to change this varies depending on what PDF driver you are using.
dawson.lim
Hi, both of our PC having the same settings & same drivers but the output is different
dawson.lim
both of our PC have the same hardware but the printing output is different. any idea?
Alfred.NESWADBA
can you please ... on both workstations:
  • start command _ABOUT ... upload a screenshot of that dialog
  • start command _PLOT ... upload a screenshot of that dialog
  • in the plot dialog click on "PDF Options" and show a screenshot from that
- alfred -
Alfred NESWADBA
rkmcswain
The hardware has nothing to do with it. It's the settings in the PDF driver. Yours is not the same as the other, or perhaps your PC is missing that particular TTF, so it can't be included.
What PDF driver are you using?
dawson.lim
We are using Tracker PDF Xchange Editor in our workstations. The differences between our workstations is she has a several versions of autocad & revit; I only have autocad version 2010
dawson.lim
Pls find the screenshot requested.
dawson.lim
My screenshot
Alfred.NESWADBA
these are the differences:
  • you are using AutoCAD 2010, "she" is using AutoCAD 2018, 2010 has a much older version of "DWG to PDF" driver.
  • you are plotting to A4, "she" is plotting to A0, which means her output is much bigger, so displaying on the display with the same size means a very different display scale.
- alfred -
PS: "she" should install updates for AutoCAD 2018, there is no update installed, but update 2018.1.2 is available (and the must current one today).
Alfred NESWADBA
