Johanna_Esteban
en respuesta a: Anonymous
HI @Anonymous,
This is the result of using LOFT from the surface you attached, two points to mention:
1. The amount of points that the edge of the surface has are too many, this is reflected in the amount of faces that go along the solid.
2. Although the surface must work properly to model the handrail, a lighter polyline will offer a better result.
I have redrawn the border with lines and arcs and through PEDIT I have converted them to polyline, once I have copied it and ALIGN to each of the surfaces that you initially had.
Then LOFT, selecting the edges one by one (in the order I want it to run) and then selecting PATH in the suboptions of the LOFT command. The result: less time in modeling and a lighter and easier to handle part.
I attach the dwg file.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! :cara_guiñando_un_ojo:
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
