en respuesta a: Patchy
Thanks much for your response....
I'm not sure how you are suggesting to use the BOUNDARY command - please tell me a little more.
This handrail part will eventually be machined on a CNC machine, so I need to have as little deformity as possible. I see in the returned model that there is a fair amount of deforming of the profile as it goes around the curve.  I also see that you have turned the profile vertical which I can't do, as I need to have that profile follow the path uniformly. I hope this makes sense.
Peter
