2505 Vistas, 9 Respuestas
Loft path issue
I am attempting to loft a handrail profile along a spline path (see attachment) without much success.......
My method is to enter the LOFT command, select the 4 identical handrail profiles in order, hit enter, choose Path in the command line and then select the path ( colored cyan) and then wait as the pinwheel spins for a minute or so. After waiting, the whole process stops as if nothing has happened at all.  Would anyone have a suggestion as to what my issue might be?
Thanks much,
Peter
iMac (Retina 5K, 27-inch, 2017)
4.2 GHz Intel Core i7
16 GB 2400 MHz DDR4
Radeon Pro 580 8 GB
