07-25-2019
05:08 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-25-2019
05:08 AM
Well, let's try something I thought of here ...
load the two views you want, select the floor view, change the layer, move these objects to the location you want, then give the Delete command, and select the entire floor area, so you will select the objects you want to keep and the ones you want to clarify.
Then, before completing the Delete command, type R to remove objects from the selection, and then type P to search for the last objects that were moved, that is, the floor objects. When you enter Enter, the floor objects you want will be kept, and objects from layer 0 will be deleted.
