- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
For certain objects (circles, rectangles etc) I can change the dimensions (length, width, radius) after they're already drawn by using of "stretch" command. But when it comes to polygons, "stretch" only moves one side!
Is it possible to change the radius of a polygon in any other way?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Perhaps you didn't understood how stretch works, but at time i don't undersatand what do you mean?
Can you share 2 picture or dwg, before->after - so i can see what you like to do?
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
in AutoCAD there is a POLYGON command which draw a polygon shapes ( Polyline ) NOT a polygon objects unlike CIRCLE command which draw a circle shape and object ( has an Radius option in Properties ). for that the only way to change the radius of an already existing polygon is by Scale command .
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
drawn a polygon with a radius of 5 inches. Now that it's drawn, I want to
change it so that the new radius is 10 inches.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
POLYGON is not an object, it is just a little helper function for you to create a POLYLINE,
in you case the solution is, as imad wrote above, the SCALE command.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
