en respuesta a:
09:37 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-23-2019
09:37 AM
A 2-step process that has helped me with similar pdf file size issues is as follows:
Open your large pdf with Adobe Acrobat, then use: file / save as other / reduced-size pdf, using the most recent file type your version of Acrobat has available in the "make compatible with" selection box, then with the file that results from this "save as" use Acrobat to "print" to a new pdf. Not sure what your e-mail size limit is, but this procedure may get your file size down far enough to work.
Hope it helps.
