Alfred.NESWADBA
en respuesta a: dmgraves
>> the temp .sv$ files are not being created in the put in time frame.
Besides of <CTRL><S> should be the friend to avoid that I would now try to set the autosave interval to 1min, then restart AutoCAD, create a new dwg-file and save it with a new name, now draw a line, every 10sec one command start ... does autosave work in that case?
  • Do you see the message that AutoCAD is doing the autosave in the command-line?
  • Do you get an SV$ file created in your folder for autosave-files?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
