natasha.l
en respuesta a: Anonymous
Hello @Anonymous,
This is the AutoCAD forum so I can only speak on the functionalities of AutoCAD, maybe another member of the community can provide advice on other Autodesk applications.
You should be able to extract attribute information from blocks or objects into a table object or CSV file for use in another application like Excel. The Data Extraction wizard is the most efficient way to extract attribute information. It can also be used to extract property values that are associated with the other types of geometry defined in a drawing along with general information about a drawing file. Then possibly use excel formulas to create/collect failure data.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
