07-15-2019
09:29 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-15-2019
09:29 PM
Are the drawing containing the block still at the same location where it was earlier?
You could also create the tool palette newly from Design Center. Press Ctrl+2 which would open up the Design Center and then navigate to the drawing containing the blocks (make sure the drawing contains all the blocks). Right click on the drawing and then select create tool palette.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
