07-15-2019
01:35 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-15-2019
01:35 PM
>> None of my lights brighten anything.
In most cases, when command _RENDER shows a black window as result, the UNITS are not set correctly.
Look to command _UNITS and verify the dimensions of your object and the distance of your light to the objects.
>> I'm in realistic mode.
Visual styles in AutoCAD are dependent on the graphic card you have build in, you need to start _RENDER to verify the complete settings, if they are correct or not.
You might upload the dwg-file and let us know which version of AutoCAD you are using, so we can test your file on our workstations.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
