621 Vistas, 3 Respuestas
Can't get Hatch to work
I'm not sure why, but I can't get this particular hatch to work. It used to work fine, but now it simply won't show up. I've tried it in different drawings, different layers, different scales, tried downloading it again from the source (http://micastoneworks.com/resources/hatch-patterns). Not sure what is wrong.
Attached is the pat file and a video. I'm using AutoCAD LT 2019.
Please help! Thanks.
Alfred.NESWADBA
en respuesta a: Anonymous
can you open my drawing and do you see the hatch pattern now?
If you try to add new hatches in this/my drawing, does it then work?
Make sure you have set HPMAXLINES to 10000000
If that does not work in your dwg-file, then please upload your dwg-file so we can look into it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
en respuesta a: Alfred.NESWADBA
That worked. You're the best, thanks!
Thank you!!
