- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Export to PDF, create spaces between letters in texts that doesn't exist
I have some texts in a layout and when I exported it to PDF, using Print and open the PDF with Acrobat Reader, I see a space between two letters that doesn't exist in the dwg file. I tried to repeat the printing in PDF and I realised that some times the space appear and some times don't. I can't realise what is going on. Any ideas?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Within a text, a mtext, an attribute, ...?
Are you using special fonts? Which ones did you use?
Which driver did you use to print, try "AutoCAD PDF (General Documentation).pc3"
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It's mtext, the font is Arial, and the driver I use is "DWG to PDF".
Thank you very much!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
can you please start command _ABOUT and show us a screenshot, so we see which AutoCAD version (and service pack) you are using?
Also please upload the dwg-file + the PDF-file you get as result (just a few of your mtext objects, and a layout that is already configured ready for printing with your settings).
- alfred -
Alfred NESWADBA
