>> I associated autocad files to the acad.exe
In March you accepted my suggestion as solution ... to NOT use acad.exe as default to open a dwg-file?
Why did you change it back to acad.exe (instead of using the AutoCAD DWG Launcher)?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
