338 Vistas, 7 Respuestas
Blank page when converting to pdf. Beginner user please help.
As tilte i'm not sure what has happened. I haven't had this problem before. I have tried to look up the answer but my AutoCad knowledge is very limited.
Any help would be much appreciated!
See attached file.
qnologi
en respuesta a: Anonymous
en respuesta a: qnologi
Yes I have seen that but I'm not sure I understand it.
qnologi
Alfred simply explained that you should  "plot the "Layout" content and not the "Extents" area"
Hope it helps
qnologi
Just tried plotting in layout instead of extends but it is still converting to a black page.?
qnologi
After setting up your "plot in the page setup manager" does it appear as if it will plot correctly?
qnologi
Ok im getting somewhere now. It is now converting to pdf when plotting using layout but half of the drawing has been cut off.
Ok it seems if I convert using view instead of layout it converts
correctly. Not sure if this is the right way to do it but its works for
now. Thanks for the help!
