- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
First off thanks for all the help. I've been pulled off this job but, still looking into the issue. It still hasn't be worked out completely. Pushing this back to the Classification Society.
@pendean I have tried what you said and changed the line weight for the text layer. While it made the text darker, every other pair of letters/numbers came out the same way. I have a feeling it has something to do with the width of the text. While we typically use the ROMANS font and width set to 0, I think, we haven't had any problems like this. Even using the monochrome ctb file. Vertical and horizontal have different weights/widths when zoomed to extents. When we zoom in, at any percentage, the lines balance out or look the same. I didn't have the budget to fix all 4 sheets to the drawing, only had the time to modify what was needed for the project. There was a lot of single line text on the drawing.
Again, I would like to say thanks for the help!
Best Regards,
Rick
