I did but I am not getting the same results that I use to :(.
My title blocks are made in such a manner that they have two levels to them. All the attributes info, such as drawing title and scale is on the lowest level that is a block, titled "user input" then the next level up is all of the title block itself with line work that the user can alter.  Let me attach an example and you can see what I have.
Previously on an earlier version of AutoCAD I was able to insert what I am attaching on to the tool palette, and then adjust the option on the tool palette to explode upon insertion. Once that I did insert the block from the tool palette the "DDATTE" dialog box would appear automatically. I can not for the life of me get it to work in this manner now.
I have removed some stuff due to company requirements.
