- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello @rvtquestions,
Thank you for providing this detailed information, it really helps. Some of the other suggestions are listed below, but is concerns me that the UCS seems to be out of whack. To reset it on the command line in AutoCAD, type PLAN and then World.
Where did this file originate from did you import this file into AutoCAD from a 3rd party application?
Replace the Z value For 3D objects in layout viewports:
- Enter OPTIONS in the command line.
- On the Drafting tab.
- Under Object snap options.
- Check Replace Z value with current elevation (not available in AutoCAD LT).
To flatten a drawing manually (or as needed in AutoCAD LT):
- Select objects with the QSELECT command:
- Select the object type.
- Choose the Elevation (or Start Z or End Z), and then Not Equal To > 0 (zero)
- In the Properties palette, change Elevation (or Start Z or End Z) to 0 (zero). Note: To use this method with certain objects such as blocks and groups, you need to explode the objects first.
- Use the CHANGE command:
- Type in the CHANGE command.
- Type ALL to select all objects and then Enter.
- Type P for Properties.
- Type E for Elevation.
- Type 0 and then a final Enter to end the command.
More suggestions can be located here.
Let us know if your still have issues with your UCS.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
