zachUDEDM
2795 Vistas, 9 Respuestas
Reduce unwanted snap points
I'm sure everyone has had the issue of autocad snapping to a point that they didn't want, and using the on/off toggle or the temporary snap option helps to mitigate the issue.  But the times that I find most frustrating is when AutoCAD snaps to a point that isn't even visible on my screen.  This does crop up most commonly from large objects like PDFs, Blocks or Mtext but I can't think of a single instance when someone would want to snap to a point that they aren't currently looking at.
Is there a way to constrain the snap function so that it only looks for objects in the current view rather than a set distance away from your cursor?
Is there a better place to send this suggestion to Autodesk to have this added in to future editions if it doesn't currently exist?
