06-27-2019
01:45 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-27-2019
01:45 PM
>> I repair the AutoCAD 2008 and without luck.
Do I understand you correct, you are working with AutoCAD 2008?
If yes ask the sender of the dwg-file to use command -EXPORTTOAUTOCAD to save his drawings back to DWG2007, and this needs to be done with all files, also with the referenced ones.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
