apanbasu
845 Vistas, 12 Respuestas
Crashed drawings
I have received the attached E-transmit file and after unzip I converted the file o 2007 version. First time when it failed - iasked the sender to send me again. the attached is the second file. Whenever I tried to open the file the software crashes with fatal Error (See attached) I ran Recover and and it came out OK and then when it tried to open - it crashed.
I repair the AutoCAD 2008 and without luck.
The gentleman send me two more drawings and they were fine.
Will somebody help me ? What should I do to open the drawing?
Thank you.
Alfred.NESWADBA
en respuesta a: apanbasu
Do I understand you correct, you are working with AutoCAD 2008?
If yes ask the sender of the dwg-file to use command -EXPORTTOAUTOCAD to save his drawings back to DWG2007, and this needs to be done with all files, also with the referenced ones.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
pendean
...or you can correctly knock down the files yourself to 2007dwg file format with the DWGTRUEVIEW free viewer and it's DWGCONVERT feature https://knowledge.autodesk.com/support/dwg-trueview/learn-explore/caas/sfdcarticles/sfdcarticles/How...
pendean
apanbasu
en respuesta a: pendean
The drawings were made in 2014 LT. when I received E-Transmit file I
converted to 2007 version using Drawing Truview 2018. I can open this
drawing in Trueview. Unfortunately, I cannot save the opened file in
Trueview. There are three separate e-transmit files were mailed to me. After
conversion, I had no problem opening two of them This drawing is giving me
trouble. I have requested to save the drawings in 2007 version and mail me
the drawings. I have not received the converted drawings yet. Let me see
what happens when I have the drawing.
pendean
>>>... I cannot save the opened file in Trueview...<<<
Why not? We all can and do all the time
apanbasu
I did every thing suggested. I had the drawing saved in 2007 version and saved the drawing in different name. Still it crashed. I do receive drawing from this gentleman regular basis and occasionally I had a situation where symbols may not show. That is resolved by blowing out the symbols and save the drawing in 2007.
But, this one will not budge. I have attached the drawing. if somebody could help.
ennujozlagam
can you try these 2 files attached, if works to you. thanks
pendean
en respuesta a: ennujozlagam
See attached.
HTH
apanbasu
Thank you. Thank you both. I do not know what you did - it worked. Can you tell me what you did that I can I do if this happens in the future. Otherwise I will lean on you guys. Stay there as long as I am kicking.
Thanks again.
pendean
I used the AECTOACAD command in AutoCAD2019 to knock your files down (the program I already had open on my PC at the time), not much else really.
Alfred.NESWADBA
Strange ... have you ever looked to post 2 in this thread?
- alfred -
Alfred NESWADBA
apanbasu
I did nor mean to offend you in any way. In my post I stated both solutions. I did not realize I need to check both posts for the solution.
Thank you.
