197 Vistas, 1 Respuesta
Edit/Convert Text Number Values
I'm currently looking to edit all of the contents of a layer of multiple text boxes. Right now my method produces a new value (which is also okay, I just am trying to do it all in one go). I have a large array of texts with number values that are currently in decimal form (representing inches). I need to convert (or produce a new item) each one to feet in fraction form. I can currently do this one at a time using "field > formula > insert field > select object > contents > divide by 12 > additional formatting > conversion factor of 12 > set as architectural". I need a way to do this all at once by selecting the contents of a layer or something but cannot figure it out. Hopefully someone can help. Thank you.
Kent1Cooper
en respuesta a: Anonymous
See >the other one< over in the Customization Forum [a better place for it].
Kent Cooper, AIA
