06-27-2019
05:15 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-27-2019
05:15 AM
Forgive me, but I'm not sure I understand all that you are going on about: the simple issue is the file is drawn with no line weights and uses SHX "stick" fonts that have no line weight either.
All easy to fix with either LWEIGHT settings to objects, or line weight settings in your plot style table, and possibly changing the SHX fonts to TTF inSTYLE command.
Or as noted by others do you just need to use a different PDF viewer so you are not so distracted by Adobe Acrobat's gimmick settings to speed up that bloatware of a viewer?
