06-26-2019
01:12 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-26-2019
01:12 PM
Unless you made changes to it, the MONOCHROME.CTB plot style table does absolutely no lineweights what so ever by default, and when I turned on LWDISPLAY and zoomed into your modelspace content I saw no lineweights set that way either.
SInce you use SHX fonts in the file, they will also need to be set with either a physical LWEIGHT setting or to a pen with a lineweight setting in your MONOCHROME.CTB file.
What is your AutoCAD experience level if I may ask? it helps others better explain how to address your issues if the info I provided above did not shine a light on the issues for you to address.
